Discussion topic: Looking for 2.4 GHz speed from my Sky Broadband Router. Default is 5GHz.
This message was authored by: TOKS1
I been told that I should go to my rauters settings and rename both speed for example 2.4GHz and 5Ghz then those options will show when you searchin the wifi connections and you can choos either. My wifi security cameras require 2.4Ghz, I would like try this firs before I bay new more uptodate cameras.
Re: Looking for 2.4 GHz speed from my Sky Broadband Router. Default is 5GHz.
@TOKS1 What sky Hub do you have, see the link below and say what you see! Router is both 2.4/5 with a single ssid. 2nd link explains all you need for the SR203 Sky Broadband Hub!
Split Sky WiFi bands
Avatar for TOKS1
Thank You Jim, You were very helpfull.Now I know where to go.
TOKS
