Discussion topic: Logging into external VPN
This message was authored by: HJ60
Problem logging into external VPN from Sky router - any tips please?
Re: Logging into external VPN
@HJ60
The forum needs way more info than that.
Please tell us more about your setup e.g. what Sky hub you have? What device you are using to connect to the VPN? How is this device connected to the hub (WiFi/Ethernet)? What VPN is it? What error messages do you get?
I am NOT a Sky Employee
