Discussion topic: Literally unplayable gameplay due to latency and jitter spikes!!!
This message was authored by Treblered99 This message was authored by: Treblered99
I've had this sky broadband superfast since last January,,,, my speed is 70mb download and 18mb upload,, and from the start on my xbox one s,,,, literally unplayable gameplay and its not the ea severs,,,, as I've had 28mb on EE broadband and never ever had this much as a problem with online gaming!! Basically mov3d back into my bedroom and it's exactly the same I use cat 8 ethernet cable directly from the xbox to the router,,,, so its mot because I'm using WiFi,,,, I've even opned the ports to my xbox properly and still the same can someone suggest or help me out as I'm on the verge of cancelling my contract! I've payed over £200 on the new xbox and eafc 24 game to literally have a game and turn it off!,,, I cam post router stats
Treblered99
Re: Literally unplayable gameplay due to latency and jitter spikes!!!
Basically I live in a bedsit so my router is in my bedroom down stairs I've got the adsl box in my room
This message was authored by mae-3 This message was authored by: mae-3
@Treblered99
Yes please, can you post the router stats?
Treblered99
@Treblered99
Just waiting for that screenshot of the router stats to be approved by the power to be.
Treblered99
Ok thankyou
Treblered99
This my bqm graph,,, since I've opened the ports,,,, before that was showing as green as low as possible with 20-30ms yellow latency,,, but the game play was just as erratic,,, hence the opening of the ports to my xbox
@Treblered99
The router stats show that the connection has been up for 8 hours and you are connected at the maximum speed, eg: 80Mbps downstream and 20Mbps upstream, for the service. The router stats don't show a clear fault, and there is nothing connected by ethernet so assume one is using wireless mainly which can be troublesome occasionally for gaming.
I'll give my thoughts on the latency chart once it has been approved.
@Treblered99
The BQM is for the IPv6 client address one really needs to do the BQM for the public IPv4 address, as this allows one to see whether it is a broadband fault or an internal LAN/WAN network issue. Suggest, you set up a public IPv4 BQM monitor which measures latency to the router.
Treblered99
Ok I'll try that now,,, have you had a reply regarding the router statistics
@Treblered99
I've posted about the router stats already, three posts up. 😀
Treblered99
I'm a idiot,, the xbox is off hence not showing the ethernet cable being connected am I correct?? Shall I redo router stats when the xbox is on
@Treblered99
Don't worry about that the Xbox was off the latency chart for the IPv4 public address is more important for diagnosing an issue with the broadband line itself. So, suggest you set that up now and post in 24 hours with those details.
Treblered99
Ok thank you and leave the ports I've opened up on the router until then yes,, thanks
@Treblered99 you mention eafc strangely we get a sudden peak on complaints about latency when  EA launch their annual upgrade oddly often only affecting that game. Do you get similar problems with other games nit from EA?
