Discussion topic: Line issue fixed
Message posted on 08 Jun 2024 01:29 PM
Line issue fixed
Hello, I wonder if you could all advise me on how much potential speed I could gain. I had a line issue which has now been fixed, but because of this, I have lost about 5 MB of my broadband speed, I was on a 3 dB margin and was connecting at around 70. Is dropped off slightly and the SNR has gone gone to 5 but the fault has been fixed. How much more speed do you reckon I can gain when DLM sorts the line? These are my current stats because of the fault which has now been fixed, I was told that the DLM should automatically bring it back up now the issue has been fixed.
Broadband Link Downstream Upstream Connection Speed 65044 kbps 10475 kbps Line Attenuation D1(17.7 dB) , D2(45.9 dB) , D3(69.8 dB) U0(6.0 dB) , U1(35.4 dB) , U2(53.7 dB) Noise Margin 5.1 dB 6.1 dB
Message posted on 08 Jun 2024 01:35 PM
Re: Line issue fixed
At the minute the ds is below 6db which means dlm is trying successfully to bring it down to 3db. Once it is down to 3db i see no reason why it can't go back to what is was assuming you do not reset the hub
Message posted on 08 Jun 2024 01:44 PM
Thanks i will leave well alone now. So should go back up to 70 or more, are my stats impressive for my length of line.
Message posted on 08 Jun 2024 01:46 PM
Maybe another 2-5 Mbps if all goes well
Message posted on 08 Jun 2024 02:00 PM
I think every decibel is about 3megabytes so yes could end up around 71 give or take a megabyte, it doesn't need a dlm reset the engineer told me. Should do it itself
