Discussion topic: Leeds no connection
Message posted on 09 Jul 2025 01:44 AM
Leeds no connection
Live in leeds city centre. All green lights on the box but still not allowing any signal to any devices
Message posted on 09 Jul 2025 02:01 AM
Re: Leeds no connection
Yes, Me too. in the Bridgewater area.
suddenly lost all the connection.
Message posted on 09 Jul 2025 03:34 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
