Discussion topic: Sky Broadband issues during the night
Message posted on 09 Jul 2025 01:18 AM
Message posted on 09 Jul 2025 03:38 AM
Re: Sky Broadband issues during the night
@RickBusby wrote:
my Internet keeps going off late evenings & nights when I'm trying to do work.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
You mention evenings as well so if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Remember Sky Broadband is a domestic service so you won’t receive any quicker or extra support if you're wfh.
