Discussion topic: Late May BH
Message posted on 25 May 2026 11:36 AM
Late May BH
Message posted on 25 May 2026 12:04 PM
Re: Late May BH
@K4471 are you saying their is an issue with devices connected directly to the Skyhub's WiFi or those connected to the Devolo's WiFi or both?
Having two WiFi unmatched sources in the same property can cause interference if they are on using the same or adjacent WiFi channels. Rebooting the Sky hub may sort that as the hub should find the least congested channels when re-starting.
Message posted on 25 May 2026 12:34 PM
Re: Late May BH
All connections are status - but WiFi connection drops on some devices.
I've rebooted Devolo and let all devices connect director Sky Hub Max.
Just find it weird mobiles are dropping connection too.
Thanks for your feedback.
Message posted on 29 May 2026 06:29 AM
Re: Late May BH
Resolved.
I synced all the SKY router servings with the Devolo products.
I now have a stable WiFi connection.
