Discussion topic: Laptop not connecting, everything else is
Message posted on 20 Sep 2024 07:14 PM
Message posted on 24 Sep 2024 03:37 PM
Re: Laptop not connecting, everything else is
Is it connected via WiFi or ethernet? Do you have anything running on it that could block internet access like a VPN or over enthusiastic antivirus?
Message posted on 24 Sep 2024 05:56 PM
I have now resolved the issue. After much trying (no VPN etc issue) ,I separated my 5GHz and 2.4GHZ and have found by logging in via the 2.4 it works perfectly but will not work on the 5GHZ..
Message posted on 24 Sep 2024 07:54 PM
This sounds just like my issue. I'm really shocked Sky haven't acted and resolved this for it's customers.
How did you seperate the 2.4 and 5 on your router please?
Message posted on 25 Sep 2024 12:21 AM
I went into my sky hub settings . Then in the tab "WIFI" it should have two tabs underneath , one saying 2.4 and one saying 5. I renamed them both so I could tell them apart and then unticked the box which says "Synchronise 2.4 GHz and 5 GHz Settings"
