Discussion topic: LOS light showing red
Message posted on 04 Dec 2025 12:33 AM
My WiFi box is flashing green but the LOS light on the openreach box on the wall is red , I'm unsure on what to do as this is effecting my whole home
Message posted on 04 Dec 2025 12:35 AM
Re: LOS light showing red
Same
Message posted on 04 Dec 2025 12:36 AM
Message posted on 04 Dec 2025 12:37 AM
Same thing happening with mine too
Message posted on 04 Dec 2025 12:39 AM
Same thing bud
Message posted on 04 Dec 2025 12:40 AM
Mines also dropped out, last time it was a damaged fibre but assuming with so many people this may be a bt/sky issue
It's maintenance I think, 12am-7am
Message posted on 04 Dec 2025 12:41 AM
Same!
Same in Dorset
I have the same thing
Message posted on 04 Dec 2025 01:28 AM
Where have you read this?
Message posted on 04 Dec 2025 03:42 AM
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, post back in this thread and we can try to offer additional advice.
Message posted on 04 Dec 2025 07:55 AM
The forum has been seeing a lot of similar reports recently where overnight maintenance is causing the red LOS light. This means the ONT is not receiving any optical signal. The most likely explanation is that Openreach are doing a programme of work on the OLT units in the exchange that generates the optical signal which requires these to be shut down for a brief period.
