Discussion topic: Keep loosing signal
This message was authored by: Niki10
Message posted on 13 Apr 2025 08:00 PM
Keep loosing signal
We seem to have intermittent broadband even though all the tests are showing ok
This message was authored by: peter-marlow+1966
Find out more
Message posted on 13 Apr 2025 08:27 PM
Re: Keep loosing signal
Is it the wifi you are having problems with? Wifi signals can be unstable especially if you have many devices connected to it also your speed might not be up to it can you connect any of the devices with an ethernet cable? What is your broadband speed ?
P c marlow
