Discussion topic: No internet light on sky broadband hub
Message posted on 13 Apr 2025 08:21 PM
I've checked all connections and done a test it says no problem but there obviously is the power button is on the power light is green , wireless light is green but internet light is not on
Message posted on 13 Apr 2025 08:28 PM
Re: No internet light on sky broadband hub
@Sco3
This should determine if there's an identified fault affecting multiple households.
