Discussion topic: Keep loosing connection
This message was authored by: NigelTomkins
Message posted on 30 Jul 2024 05:51 PM
The internet keeps cutting in and out for about a week, however the last 24hrs it has happened very frequently and causing issues with working from home. By the time I check the router it's all green, run your checks that say all is ok but isn't.
Find out more
Message posted on 30 Jul 2024 07:31 PM
Re: Keep loosing connection
@NigelTomkins Are you just getting to the service checker area with the house in the background?
