Discussion topic: Keep loosing WiFi
This message was authored by: Cheryl2806
Message posted on 23 Apr 2024 08:15 PM
Keep loosing WiFi
Over the last 5 days I have lost WiFi 6 times. Everything I run a diagnostic test on the sky app it says there is no none fault. There's obviously is otherwise it wouldn't stop working. Can someone look if it's my WiFi box or a bigger problem? If it's my WiFi then this can be replaced. Thank you
Find out more
Message posted on 23 Apr 2024 08:18 PM
Re: Keep loosing WiFi
Does the internet light on your sky router turn amber?
Could you post your hub stats as shown below
