Discussion topic: Josh mason
This message was authored by: Josh145
Josh mason
There was a issue in my area earlier it came back on and now it's off again
Re: Josh mason
@Josh145
If you still have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
