Discussion topic: Internet No Connection
This message was authored by: Courtneyw02
Someone DDOS attacked my WiFi now I can't get online it's been 7 hours... it shows all green lights but no internet connection working.
Re: Internet No Connection
@Courtneyw02
Why would someone attack your wi-fi?
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
