Discussion topic: Issues with wifi
Message posted on 27 Nov 2025 09:42 AM
Issues with wifi
Hi,
my WiFi doesn't reach all my rooms, which is causing me issues as my 4g is being drained and so I am running out of data on my phone because of it. It's the back of the house on both floors.
Message posted on 27 Nov 2025 09:44 AM
Re: Issues with wifi
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 27 Nov 2025 10:29 AM
@Amanda19851115 You can also disable the mobile data when you are at home, then see if the mobile will hang onto the wireless wifi connection!
