Discussion topic: Issues with wifi
This message was authored by: CM37
Message posted on 20 Nov 2025 11:05 AM
Issues with wifi
I seem to have an issue with my router. My Wi-Fi keeps going down and I keep needing to turn it off and on again to get it to work. I'm wondering if I need a new router?
Message posted on 20 Nov 2025 11:11 AM
Re: Issues with wifi
@CM37 If you find it easier, then when at home call sky they can run a diagnostic from that side, see what is going on and give you the advice when/if they see any issue! Call 150 from your landline phone if it is indeed working, if not then 150 if you also happen to have a sky mobile will get you there!
