Discussion topic: Issues with wifi
This message was authored by: Mon12mon
Issues with wifi
My internet keeps cutting out everyday for the last 4 days.
it is causing issues with my work and also turns off at night which is now affect my home security.
i need this looked into ASAP someone need to contact me.
this is unacceptable service and I need some sort of compensation for the amount of times this keeps happening
Re: Issues with wifi
@Mon12mon
Firstly, in case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers. No one will / can phone you. Your Community tag name isn't linked to any Sky accounts you have so no one knows who you are.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Sky normally quote 2 WORKING DAYS as a potential fix time. This is the service level agreement in the UK between ISP’s and Openreach for fixing a fault as Openreach claim to be successful within that timeframe in 85+% of cases.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
As Sky broadband discussed here is a domestic set up there is no extra or quicker support for those working from home.
