Discussion topic: Issues with one website
Message posted on 22 Sep 2024 02:12 PM
Hello. I am having issues with the online indoor cycling site, Rouvy since last week. It will not allow me to access any of the rides. It allows me into the site but when I try a ride, it says please try later. I've reported it to Rouvy but they have said its our Internet. I've turned the router off for an hour and tried again but still doesn't work. I tried it on my phone data plan and it worked straight away but that will wipe out my data. Any advice please?
Message posted on 22 Sep 2024 11:23 PM
Re: Issues with one website
I'm also exp8rhe same issue. It works fine thrpugh my mobile network but not with sky
Message posted on 23 Sep 2024 01:06 PM
Is there anyone from Sky on here to help please?
Message posted on 23 Sep 2024 06:13 PM
To update, this is what I've tried without success:
I've tried disabling sky shield
Using alternative DNS servers
Powering the router off for 30 minutes
Plugging directly to the router via ethernet
Using multiple devices
The problem also appears to affect video playback of any of the courses on rouvy.com which can be used as a quicker method of testing. Access to the website itself appears to be unaffected.
Message posted on 23 Sep 2024 06:24 PM
Hi @Montof I've spoken to Sky and it's our router so we are being sent a replacement one to try
May be worth requesting one too
Message posted on 24 Sep 2024 09:18 PM
We now have our new router and still does not allow access unless I install a VPN
This has a monthly subscription so any advice please?
Message posted on 24 Sep 2024 09:25 PM
Hi Markstev, i did suspect that the router would not solve the issue as I tried using using a VPN through my Sky connection and this got Rouvy working. This pretty much confirms this is an ISP issue, and as mentioned earlier, I suspect it specifically relates to sky blocking wherever Rouvy host their video content, as the site works ok otherwise.
BTW, I've raised a ticket with Rouvy, but I strongly suspect they won't be able to do anything. I'll keep you posted if I hear anything though.
Message posted on 25 Sep 2024 10:55 AM
Hi, I've had a response from Rouvy (below) which pretty much confirms the suspected issue with sky blocking their video content and that they were already aware of the problem. I've shared my public IP and I'll let you know if hear more.
At least they appear to be more engaged than sky.
Thank you for reporting this. We are aware of the issue and our developers are working on a solution. Currently there is no other workaround than either using a VPN or a mobile network to load your workouts.
Can you please provide me with the IP address on the device you are using for ROUVY? You likely know how to find it, but if not you can easily get it from this site: showmyip.com
The devs have requested IPs to help them in their process.
Message posted on 25 Sep 2024 11:04 AM
@Montof do you have the white Sky hub or one if the older black one? Sky will not be blocking the traffic - they simply dont do that unless it is subject to a court order - but their network set up might cause issues.
The new white hubs are using a new system of assigning the IP4 addresses where up to 8 customers share one address which might, emphasise might, be the issue. If you have the new white hub try the steps I outline in this post UPnP set up which will swap the set up to an IP4 address just for your connection. Can you report the ourcome. This does not apply to the black hubs.
Message posted on 25 Sep 2024 11:18 AM
Hi @Chrisee I have a black hub. A replacement one was delivered yesterday
Message posted on 25 Sep 2024 12:16 PM
I also have a black hub
Message posted on 25 Sep 2024 01:17 PM
Latest from Rouvy
Hector Martinez (ROUVY)
Sep 25, 2024, 13:33 GMT+2
I have forwarded your information to our dev team.
They informed me they have already sent information and are awaiting a response from SKY. Hopefully we have more information soon.
Message posted on 13 Mar 2026 07:31 AM
Hi - A while after the comments below, I had the same problem (so frustrating, out of the blue, have had my white router for months) and the UPnP solution worked.
Thanks!
