Discussion topic: Issues with connection
Message posted on 17 Jun 2024 01:16 PM
I have 3 ring cameras for security i get them all connected even replaced a device so its brand new and they are constantly dropping connection which kind of defeats the object of having them. Also in my work room the connection is awful. Everytime i do the checker it says its good connection but im getting pretty sick of the cameras now
Message posted on 18 Jun 2024 10:22 AM
Re: Issues with connection
Where are these cameras located? If they are outdoor ones it can often be difficult for WiFi signals to get through outer brick walls. You may need a booster or two.
Message posted on 18 Jun 2024 10:32 AM
Hiya yes they are both outside but pretty close to the Reuter how much are the boosters as I would need 3 I think many thanks
Message posted on 18 Jun 2024 10:34 AM
Distance from the router isnt really applicable when you are trying to connect devices outside external walls.
You can't buy boosters directly from Sky, they are only loaned out when you have the broadband boost addon. Additionally I am not sure if Sky would provide you with them under the guarantee because the cameras are technically outside your home.
You may be better off looking at 3rd party options like a mesh system.
