Discussion topic: Issues with Hub
Message posted on 25 Feb 2025 11:20 AM
Issues with Hub
Message posted on 25 Feb 2025 12:18 PM
Re: Issues with Hub
@AlexKirk most likely cause is the cable connecting the hub to the incoming line is loose the plug has a catch which needs tonclick in. Check the cable carefully as that is more likely than a dodgy hub but that's also possible.
Message posted on 25 Feb 2025 12:39 PM
Re: Issues with Hub
I have tried pulling each wire and they feel locked into place. They have also clicked when removing the wires. The signal does not really drop really when touching them. However if you move the box even slightly then the hub light goes red.
Message posted on 25 Feb 2025 09:00 PM
Re: Issues with Hub
Message posted on 19 Mar 2025 10:17 AM
Re: Issues with Hub
Message posted on 19 Mar 2025 02:30 PM
Re: Issues with Hub
@AlexKirk Sky can't respond to a forum post so give them a call.
