Discussion topic: Issues signing into hub/router
Message posted on 22 Dec 2023 03:14 PM
I have tried to enter the username as 'admin' and tried both 'sky' as the password and the password on the back of the hub/router and neither are being accepted and there's no option for 'forgotten password' to reset it.
Please help!
Message posted on 22 Dec 2023 03:47 PM
Re: Issues signing into hub/router
@scullybug Which hub do you have from the link below.
Message posted on 22 Dec 2023 04:01 PM
I have the sky q hub
Message posted on 22 Dec 2023 04:32 PM
@scullybug You can find how to access the router panel in the image below.
Message posted on 22 Dec 2023 05:31 PM
Username admin and password sky didn't work, neither did the password on the router panel - that's why I posted on here, because I still can access it.
Message posted on 22 Dec 2023 05:47 PM - last edited: 22 Dec 2023 05:49 PM
@scullybug wrote:Username admin and password sky didn't work, neither did the password on the router panel - that's why I posted on here, because I still can access it.
I expect the username and password are case sensitive - make sure you use lower case for both.
If that doesn't work it sounds like the password has been changed at some point - you will need to perform a factory reset by using the button on the back of the hub. (press and hold for > 10 seconds)
Message posted on 22 Dec 2023 06:45 PM
Thank you everyone for all your help, It appears to have sorted itself out now and is letting me back in and update.
