Discussion topic: Issue with wifi
This message was authored by: Brooke__
Issue with wifi
Wifi not connecting do not not no why
Re: Issue with wifi
@Brooke__
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
