This discussion topic has been answered Discussion topic: Disabling remote management on a Sky Q Broadband Hub
Message posted on 24 Dec 2025 11:48 AM
I can visit the router settings page from the public IP, and i want to disable it to make the router more secure, is there a way to do this?
Message posted on 24 Dec 2025 04:13 PM
To recap:
Sky Broadband hub refuses remote connections to the web ui by default.
You can add a firewall rule on top of it to make absolutely sure.
This blocks connection attempts to port 80 on your local area network's router usually (192.168.0.1) from external networks requesting resources from your network over both IPv6 and IPv4. If you, a local network user, are making requests to your own public ip address, it will bypass the firewall and remote management firewall sky provides by default.
Message posted on 24 Dec 2025 12:00 PM
Re: Disabling remote management on a Sky Q Broadband Hub
Message posted on 24 Dec 2025 12:13 PM
Sky gave it to us in replace of our old router that didnt support fibre, because we converted to fibre.
Message posted on 24 Dec 2025 12:15 PM
its this thing: Sky Q Hub: Open Source Software i might of got the name wrong
Message posted on 24 Dec 2025 12:21 PM
That's the Sky Broadband Hub: it's the successor to the Q Hub.
Message posted on 24 Dec 2025 12:22 PM
@JoesMARAGI Here is the link to the sky hub's below!
Message posted on 24 Dec 2025 03:17 PM
But is there a way to disable remote management for he web ui using firewall rules or something?
Message posted on 24 Dec 2025 03:24 PM
@JoesMARAGI Remote management is/was suppossed to be turned off / excluded for remote operation and admin for all the sky Hub's and yes there was a switch to allow such, no longer got my SR203 sky Broadband hub connected, as you have yours up go have a look and see where it is, will be in the advanced options somewhere. Are you saying you can get to it via the wan IP address?
Message posted on 24 Dec 2025 03:25 PM - last edited: 24 Dec 2025 03:26 PM
Remote access should be disabled by default in the factory settings. Are you actually accessing the Hub externally, or using the public IP from within the local network?
Message posted on 24 Dec 2025 03:28 PM
public ip from within the network, i should realy try externally shouldnt i?
Message posted on 24 Dec 2025 03:32 PM - last edited: 24 Dec 2025 03:35 PM
@JoesMARAGI Yes you should. And that would also be best served via another network completely seperate! And to the wan IP of the sky Hub! If you need will go unbox and fire up the old hub, but not going to put it online for wan connection!
If it's anywhere would think possibly support tab from memory!
Message posted on 24 Dec 2025 03:37 PM
via my phone using mobile data, it is saying: (my IP) took to long to respond.
Message posted on 24 Dec 2025 03:41 PM
Yes: doing so within the network isn't a test.
@JoesMARAGI Honestly do not think you are going to get to it as refused connection would be the norm, on a local lan yes chance it will port through as a secure network connection!
Message posted on 24 Dec 2025 03:42 PM - last edited: 24 Dec 2025 03:43 PM
That's correct behaviour: not even an acknowledgement that the IP address has something behind it.
