10 Oct 2024 12:58 PM
Yes I do.
11 Oct 2024 08:55 AM
Does that confirm my broadband type?
11 Oct 2024 09:01 AM
The ont fibre modem confirms full fibre fttp so the asus mentioned should work directly connected to the ont but if you want to retain sky internet calls you could switch wifi off on the sky hub and ethernet the asus to the sky hub and put the asus in access point mode
11 Oct 2024 09:02 AM
@ape72 wrote:Does that confirm my broadband type?
Yes, you should follow the guidance @cookiemonsteruk provided earlier 👍🏻
11 Oct 2024 01:26 PM
@cookiemonsteruk your help has been invaluable. Thank you. So if you are FTTP and have the small white ONT modem, can you plug any router into it?
11 Oct 2024 01:33 PM
If you want to replace the sky hub stick with the asus rt ax models otherwise any router can plug into the sky hub and be used as an access point . The asus rt ax52u is not one we hear of much so i use the term "should work" whereas asus rt ax58u and above will work
11 Oct 2024 04:44 PM
@cookiemonsteruk I just noticed at the bottom of your post that you still have the SR203 listed. Is there a reason you haven't replaced your SR203?
11 Oct 2024 04:49 PM
Mainly to maintain my sky internet calls also living in flats the asus wifi 6 especially on 2.4ghz wifi would interfer with neighbours. The asus rt ax are powerful beasts
11 Oct 2024 04:50 PM
Thank you mate. Have a great weekend.
13 Oct 2024 10:06 AM
@cookiemonsteruk I plugged in the new Asus RT AX58U into the ONT and it worked straight out of the box. Seeing all of the customisation available on the Asus confirms that replacing the SR203 was the right call. I don't use Sky voice calls so the SR203 is now gone. Thank you again.
13 Oct 2024 10:19 AM - last edited: 13 Oct 2024 10:21 AM
Did you enter any authentication details? If you have the connection type set to automatic ip you should see client identifier (option 61) and enter
anything@skydsl|anything
Asus are very sky friendly so the dhcpv6 prefix delegation may be activated . However its best to have 2 authentication protocols active at the same time
13 Oct 2024 01:27 PM
I didn't have to enter any option 61 details. Should I anyway?
13 Oct 2024 01:31 PM
For redundancy if 1 one authentication method fails you at least have a backup
