Discussion topic: Is my broadband 4G
This message was authored by: Digger
Is my broadband 4G
Need to know if broadband is 4G or better
Avatar for Digger
Re: Is my broadband 4G
Can you give me the answer
@Digger given 4G is a mobile technology the answer is no it isnt nor could it be. Depending on your line your Broadband either is partial fibre using VDSL where the speed depends on the length of the copper line or full fibre which delivers the speed you buy.
@Digger
The wireless broadcast from a terrestrial broadband router is either 2.4Ghz or 5Ghz (where the G is for Gigahertz)
As @Chrisee indicates, 4G and 5G are cellular broadband technologies broadcasting from masts and typically used by smartphones: the G there is for 'generation', so 5G succeeds 4G.
Sky Broadband is not cellular, but Sky Mobile provides data SIMs.
