Discussion topic: Is a flashing green LAN light normal
Message posted on 04 Sep 2024 05:56 PM
Had fibre optic installed seems ok but I have a flashing green LAN light is this normal?
Message posted on 04 Sep 2024 06:09 PM
Re: Is a flashing green LAN light normal
Flashing green on the ont?
Message posted on 04 Sep 2024 06:11 PM
Yes. The sky hub lights are all fine.
Message posted on 04 Sep 2024 06:12 PM
That just means that data is flowing between ont and router
Message posted on 04 Sep 2024 06:14 PM
Arh ok. Was a bit worried that it should be steady green light. Thanks
