Discussion topic: Ip address showing wrong location
This message was authored by: ComrieMary
Message posted on 24 Mar 2024 12:36 PM
My broadband and phone line were recently fixed and since then my ip location shows as London. Now, this wouldn't be an issue, except i have apps which will only show live TV in Scotland, where i am loacted. I have turned off the router for 30mins and rebooted and it is still the same. How can this be rectified? TIA
Find out more
Message posted on 26 Mar 2024 12:03 PM
Re: Ip address showing wrong location
Make a note of your IP before you switch off the router and then check it against the new one you should be issued when the hub is switched back on. I say this because Sky IPs can sometimes be quite sticky and will require a hub switch off of more than an hour.
I am NOT a Sky Employee
