Discussion topic: Internet was cutting out, gone now
This message was authored by: Bigtom54123
No Internet when connected
All lights are green
Turned off and unplugged devices
Need help
Avatar for Bigtom54123
Level 0 icon
Re: Internet was cutting out, gone now
Did the online test thing and didn't help
This message was authored by: Maria10
Having the same issue was cutting out and now gone. Done all of the usual things nothing is working. Sky is saying there are no issues in my area
@Bigtom54123  & @Maria10  Can you run the latter test in the directions below to see if it picks up the fault and gives you further information are you in hemel hempstead?
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
This message was authored by: Joanna+Deacon
My internet is also down. I rely on it for work and when I go on my sky app and check it says there is an outage in my area and they are working on it. Says it may take a couple of days to fix 🤦🏼‍♀️
Two working days is the Openreach target time to fix for an individual domestic fault.  An area outage would get more attention, but the time required depends on the nature of the issue: replacing a cabinet line card is rather quicker than if the cabinet itself was wiped out by a vehicle impact.
This message was authored by: MLB10
Hi @Highlinder
Have completed the test and it is saying that everything is fine but it isn't working. I have an amber light on the internet section. I do live near Hemel Hempstead.
completed all of the diagnostic tests and nothing is helping have reset our sky hub etc and still having the same issue.
@MLB10  There is a major outage around that are and there is a bigger thread about it on this board and Sky have responded and know about it.
This message was authored by: sujith
same issue with sky internet ,as it cutting out and get disconnected
@TimmyBGood No broadband, no internet, no TV..... means I might have to talk to my husband this evening! 😅
This message was authored by: ShaggyDog
There is an outage in the HP1 area
This is so annoying,  i work from home twice a week, now having to go into the office,  also cant watch tv in my area as its sky stream and cant get a reception on digital hence got sky, really annoying... couple of days is no good!!!
Thanks @Highlinder
I can't find the longer thread. Did they provide an estimate for a fix time? Trying to work from home and using my hotspot on my mobile phone at the moment.
@MLB10  Here is the longer thread
This message was authored by: Evelinazaveckai
I have same problem.
