Discussion topic: Internet speed
Message posted on 27 May 2026 07:06 PM
Internet speed
Message posted on 30 May 2026 03:11 PM
Re: Internet speed
That sounds like either the cable or the device you are using isnt compatible with gigabit ethernet. What device arer you connecting via ethernet? Is the cable your using of high quality and has all 4 pairs connected in it?
Message posted on 30 May 2026 03:15 PM
Re: Internet speed
As @jamesn123 indicates, the particular hardware is important.
For example: Sky Glass television sets and Sky Stream pucks will never show higher than around 90Mbs on a cabled connection because they only have 100baseT ethernet chipsets.
