Discussion topic: Internet speed
Message posted on 26 May 2026 02:50 PM
Internet speed
My package says I should get speeds of 600 mbs downlaod and 107 mbs upload.
I'm getting 15.5 and 22 respectively. Not what I wanted. Pleazse advise.
Message posted on 26 May 2026 04:03 PM
Re: Internet speed
@AndyPurnell if you are measuring speeds on a device connected by WiFi to the Sky hub the result is almost certainly the WiFi speed in your home which is not guaranteed as it depends on the layout of your home and how it is built. You can check the speed to your hub which is checked daily by looking at the service checker in the My Sky app. In the unlikely event thst is lower the app should offer further help.
In practice 155Mb/s is ample for the vast majority of apps but if you feel you need more it is likely you would need to invest in several hundred pounds worth of WiFi kit as Sky's WiFi Max only guarantees 25Mb/s in every room in your home.
