Discussion topic: Internet speed
Message posted on 15 Apr 2025 09:17 PM
Internet speed
Message posted on 16 Apr 2025 06:53 AM
Re: Internet speed
@Louise71 if you are measuring speed on a device connected by wifi it is likely you are just measuring the wifi spedd between the hub and tour device. The service che ker in the My Sky app will tell you the speed to the hub.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
