Discussion topic: Internet speed dropped to below half.
Message posted on 27 Sep 2024 02:19 PM
Hi folks,
Over the past three weeks, the connection speed to my router has dropped from 80000kbps down to 34998kbps. Initially it dropped exactly half and then settled where it is now.
i have fibre to the building and the remaining copper line is about 25m long.
Is there at sky who can take a look?
Message posted on 27 Sep 2024 02:22 PM
Re: Internet speed dropped to below half.
@Andy214If you have a black router can you follow the directions below.
Could you please post your router stats following the link below.
Message posted on 27 Sep 2024 02:34 PM
Hiya,
I use a Vigor 2860 but the available stats are as follows:
Profile: 17A
State: Showtime
Upspeed: 19999kbps
Downspeed: 34998kbps
SNR Upstream: 8
SNR Downstream: 23
The router has worked flawlessly for many years. The only thing which I feel has changed is a recontract with Sky.
Message posted on 27 Sep 2024 02:36 PM
@Andy214Would seem that there is a fault on the line. But for Sky to sort it you might have to put on the Sky router for them to troubleshoot. Should that downstream SNR should be around 6 and not 23.
Message posted on 27 Sep 2024 02:40 PM
Hi
we are working from home. Since we moved to SKY BB UF1, still expriencing the same issues with SKY BB with slowness and interrupted connections.
We are very upset with this
kind regards
uma
Message posted on 27 Sep 2024 02:50 PM
Hiya,
I was under the impression that a higher SNR margin, the better?
I've linked to the full router stats below.
Message posted on 27 Sep 2024 03:08 PM
@Andy214 Have you called Sky at all to see if they can see a fault on the line? Because if they care able to get an engineer out to look at this, but they will ask you to put on the Sky router to do testing.
