Discussion topic: Internet so slow, and dropping
Message posted on 04 Jan 2026 08:21 PM
Message posted on 05 Jan 2026 07:18 AM
Re: Internet so slow, and dropping
@Jeveen check the speed your hub is receiving by running the Service Checker in the My Sky app. If thst is as it should be your issue is with the WiFi signal in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
