Discussion topic: Internet’s dropping in and our
This message was authored by: Leanne186
Please may check our internet over the last few days it's been dropping out.
Re: Internet’s dropping in and our
@Leanne186
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Leanne186 The Forum is not sky Customer Service so your request goes no further than what you have posted, here are a couple off help links but do say anything that is found when you look at them. Without information nothing the Forum can do. If you need to call and speak to sky, then dial 150 from your landline, 8am to 8pm!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
or
Try running the line test here to see if any faults are found:
