Discussion topic: Internet problem
Message posted on 24 Jul 2025 11:25 AM
Internet problem
Internet flashing orange on router
Message posted on 24 Jul 2025 11:34 AM
Re: Internet problem
The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
