Discussion topic: Internet problem **bleep**ing me off
This message was authored by: Me1011
No Internet and not the first time this had happened in the last two weeks or so well **bleep** off
Re: Internet problem **bleep**ing me off
@Me1011
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Avatar for Me1011
It went off for two whole days last month had engineer out fitting new this that n the other and still getting problems person in the house lost a day's work got not nothing at all reimbursement or an apology paying through the nose for a **bleep**e product stress levels through the roof and no one from sky gives a toss about it
@Me1011
If it was off for two days it wouldn't have triggered the auto compensation process.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
