Discussion topic: Internet not
Message posted on 04 Aug 2025 12:14 AM
Internet not
Internet dropped out 45 minutes ago - light not lit on router - done all the sky troubleshooting still not working
Any ideas what to do next ? I guess a phone call and engineer 😱
Message posted on 04 Aug 2025 05:16 AM
Re: Internet not
@Tk23
If your broadband still isn't working this morning use this link to check to see if there are any broadband problems or outages nearby.
