Discussion topic: Internet not working
Message posted on 31 Jan 2026 06:45 PM
Internet is not working only 1 green light is on..
Message posted on 31 Jan 2026 06:47 PM
Re: Internet not working
@Rach108
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 31 Jan 2026 06:49 PM
I'll take a look many thanks I appreciate it 🙂 ☺️
