Discussion topic: Internet not working
This message was authored by: Ned4
Needs sorting asap
Re: Internet not working
@Ned4
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
@Ned4
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
