Discussion topic: Internet not working
This message was authored by: ETTIE0163
On my router,the internet light isn't lit up
Re: Internet not working
@ETTIE0163
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
