Discussion topic: Internet not working
This message was authored by: rathkum
I have no internet connection
This message was authored by: Marcie3
Re: Internet not working
Same here. My full fibre broadband has suddenly dropped.
This message was authored by: Sandramac
I have none either
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
