2
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: Cloud2233
Orange ligjts on internet and voice. Everything else green. This had just happened out of nowhere, why?
Re: Internet not working
@Cloud2233
If it's still down this morning and you haven’t done it yet use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Typically because something unfortunate has happened in the kilometres of circuit and multiple items of associated equipment which link your Hub back to an internet POP.
@Cloud2233
