Discussion topic: Reset hub and password not working
This message was authored by: Hobbit89
My WiFi hub name and password wasn't working, so I've reset the hub and the original ones aren't working either
Re: Reset hub and password not working
@Hobbit89
When you say it isn't working do you mean your devices are not connecting, if so what happens whenh you try to connect a device to your wifi network ?
Avatar for Hobbit89
It's saying the username and password is wrong, but I've reset the hub, so it should be the preset ones on the hub shouldn't it?
@Hobbit89 That should be correct and applied, if the factory reset was done correctly, if not it looks like it has but in fact it is just a reboot of the sky Hub that is applied. Not holding the reset long enough and watching the front light change operation to see. What actual sky Hub are you using!
