Discussion topic: Internet not working
Message posted on 01 Oct 2025 02:59 PM
My internet has suddenly cut out However the checker is saying it seems ok. Nothing is connecting I have checked the wires and they are all in.
Message posted on 01 Oct 2025 03:01 PM
Re: Internet not working
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
