Discussion topic: Wifi has weak security - Now powered by Sky customer
Message posted on 01 Oct 2025 12:53 PM
On my iPhone, my Wi-Fi says it has weak security, and my Wi-Fi is generally slow. I've tried turning it off and on again! Looking online, I get this: "it indicates your router is likely using an outdated security protocol, such as WEP, instead of the recommended WPA2 (AES) or WPA3. You should log into your router's settings and update the wireless security protocol to WPA2-PSK (AES) or WPA3, save the changes, and then reconnect your device." However, when I follow directions to update it, I don't have administrative access.
Sky Messenger isn't available (is it ever?) and now just pass me back to Sky. Could anyone help me fix this, please?
Thanks!
Sarah 🙂
Message posted on 01 Oct 2025 01:55 PM
Re: Wifi has weak security - Now powered by Sky customer
Hi @Sarahjo
Which Hub do you have? You could take a photo and post it here or find it from the help article below.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 01 Oct 2025 02:28 PM
Message posted on 01 Oct 2025 02:43 PM - last edited: 01 Oct 2025 02:47 PM
You need to login to the hub admin page with a browser (login details probably on the bottom of the box) and check the security settings and turn on WPA2
very unusual for it to not be on by default though.
Message posted on 01 Oct 2025 02:49 PM - last edited: 01 Oct 2025 02:54 PM
@Sarahjo And NO WPA3 for that now box ever!
Sky Broadband hub settings | Sky Help | Sky.com | Sky Help | Sky.com
