6
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: Alexander++Kamuso
The internet  is not working   j can't  access  YouTube  Netflix  all the Apps
Re: Internet not working
@Alexander++Kamuso
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
@Alexander++Kamuso
This message was authored by: SuzanneG2015
I'm the same. Is there an outage in Chesterfield does anyone know?
@SuzanneG2015
Have you tried the advice already provided?
@SuzanneG2015 What did the service checker from above say!
This message was authored by: christie289
Yes there is!
This message was authored by: Rob_C86
It works to me but all of a sudden it goes off and restart again... It's very annoying as I have to work from home
