Discussion topic: Broadband not working
This message was authored by: adrianremus
Broadband not working at all , need help urgent
Re: Broadband not working
@adrianremus
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
@adrianremus You can give sky a call tomorrow morning 8am onwards! Run the service checker to see, or light's from the links below.
