Discussion topic: Internet not working
Message posted on 17 Sep 2025 10:14 AM
My internet had been on and off for the past 2 days, i currently work from home and had to use my mobile data hostpot.
i also have an autistic son having classes at home.
could you please check whats going on please? App shows as good connection but cant check even emails.
thanks
Message posted on 17 Sep 2025 10:35 AM
Re: Internet not working
@KarenJ3
This is a customer led discussion forum where Sky customers are here to try to help other customers. You aren’t speaking to Sky Customer Services here.
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
