Discussion topic: Internet not working
This message was authored by: JeremyGilbert
We currently have no internet. The light on the hub is red. Have tried turning it off and on with no improvement. It is also affecting the TV.
Avatar for JeremyGilbert
Level 0 icon
Re: Internet not working
I have looked it up on line and your information says there are no issues in the area.
Level 0 icon
It still not working
@JeremyGilbert
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers. We reply when we can so no need for multiple posts.
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
